Rhino 7. Why exactly is this mesh bad…?
Looks more like a bad ‘meshage’…
Hello - can you export this mesh and send to tech@mcneel.com, with a link back to this topic in your comments? Looks like we need to tune the mesh checking…
Could it be is learning from Twitter…?
Pascal, file send. Generally I have to say Rhino 7 Mesh Repair tools are not too bad.
Hello - I think the mesh is fine - Check
finds some self-intersections but actually locating these with MeshSelfIntersect
shows they are ‘fake’ - it looks like the self-intersection finder needs fine-tuning, to me.
Hi Pascal
actually I didn’t know about MeshSelfIntersect command existence. After I run Check and than MSI I got these 4 intersections. I understand these are fake intersections you mentioned…?
Maybe it is morally bad.
Yes, exactly…
OK good.
Are there any other not obviously visible mesh diagnostic or repair tools…?
If Rhino becomes judgmental I’m screwed
Check Meshes is still very buggy. This is my latest out of several different weird behaviors I’ve encounter over the past few weeks.
It says good objects but it lists 20 zero length edges and yet Repair function is not available…
Darius
Hello - can you please post that mesh or send to tech@mcneel.com with a link back here in your comments?
Thank you. I’m sure I will find out how effective your fix is…
Hi
Install this version
https://files.mcneel.com/dujour/exe/20210330/rhino_en-us_7.6.21089.23001.exe
Thank you. This build indeed fixed the issue. So far so good.
