I have a background image (jpg) that I dropped into rhino hoping to add it as a pattern to a wall, but instead it’s a huge image that sits in the background like a bitmap and I can’t figure out how to delete it. Anyone? Thank you.
Call BackgroundBitmap and choose the Remove option. Edit: That doesn’t seem to work if I drag and drop a picture.=, so never mind.
This seems to work- Right click on the viewport title. Go to viewport properties. Your image file name should show up in the wallpaper options box. Delete it.
Thank you! That did it! God bless you!
Thank you so much ![]()
