The top version has the exact data out that I want, however I don’t understand how to achieve this without flattening the entire trees of normals and points. (my full script has substantially more points to search from which slows the script down a lot)
Is it possible for me to get my circles to search for points that are in the same ‘petal’?
Hi Joseph,
I am essentially trying to get the average vector for each vertex.
Point In Curve was my initial method of getting each of the vectors that starts at the same location into the same branches to get their average.
Does that make more sense?
My goal is ultimately to offset the brep/mesh by moving each point along these averaged vectors.
I like Kim’s solution the most, it’s super simple, clean and effective
if you want to deal with breps and surfaces, this samples each surface closest point similarly to Joseph’s solution: flattening the vertex list and rebuilding the tree structure only at the end, 100% relies on Surface Closest Point Distance to be zero… so a a bit more geometrical and a bit less “smart”
but be aware that half of your surfaces are planar, but half are not (green/red colors for planar/non_planar)
As suggested by @laurent_delrieu, the white group attempts to “ponderate” by area, meaning multiply surface normal vectors by surface area before getting the average for each vertex.
Thank you so much Joseph, Kim, and inno,
I’ve found a solution that I’m happy with. I was getting a bit obsessed with optimization, as the previous iterations would slow the script down quite a lot when adding more input data.
Despite still having to flatten the points/normals, using ‘closest points’ seems quite fast/light.
