I added the slashes one by one, using Near and Perp osnaps.
The same process for every slash.
As a test, I made a few points on the upper curve, then made red lines from the points perpendicular to the other curve.
This is how I think the slashes should be.
Also the same process for every line.
i think it is not the best approach of starting on one rail and looking at the shortest / closest point on the 2nd rail.
this will introduce a hierarchy that is not wanted.
i totally agree sweep2 should support some more advanced features to orient the shapes / slashes.
planar and straighten of _blendsrf is somehow a startingpoint.
auto or smart slashes should consider and balance much more infos then just closest point:
balance the speed / spacing distribution on both rails (“constant speed … vivid”) but do not allow self intersections / overtaking
minimize (quadratic) deviation from angle between slash and tangent to 90 degree / rectangular
look at the inner speed distribution
as it is a 3d-issue, spacial orientation should also be considered.
tough their is no “best solution” but a balance of some factors.
the screenshot shows a starting point might look, evaluating from some kind of inner / average curve…
rigid orientation
i always miss somethink like _extrudeCrvAlongCrv with 2 rails.
“constant shape orientation / rigid shape” or _extrudeCrvAlongTwoCurves…
or … a better a nice option for sweep2
would be nice to have some more options / influence on the surface
I’d love to see something like this crude mock up that allows you to place one or more slashes and it then auto applies other slashes via some sort of tween operation.
imagine that it auto populates the intermediate slashes with the ability to spec a number of slashes between each intentional slash you place.
