Is this possible? i feel like I’m missing something obvious.
I only see the ability to undo in the order I created them, or run the command again.
No, unfortunately it’s not possible to edit them once placed.
Do you think it should be possible? Just curious to see what other people’s thoughts are.
Hello - these are editable in BlendSrf
(very similar to Sweep2) but the big difference is in that command the cross section curves are completely under the control of the command - it makes them up. In Sweep2, my guess is, the best that could be offered is to move the ends, and maybe-possibly the directions, of the ‘slashes’ after the fact. @lowell, am I somewhat on the right track here?
Added - https://mcneel.myjetbrains.com/youtrack/issue/RH-52647
Yes, that sounds right. In Sweep2, the slashes define parameter matching between the rails, not shapes of the surface. The sweeper makes up the shape
