I’m having an issue creating multiple layouts/details from grasshopper. This used to be done with the Layout Manager plugin where you could select boundary curves and it would create layouts, however, this doesn’t seem to work in Rhino 7
I’m using a python node created by @dharman but when I try to create the details it doesn’t align them with the layouts. Looks like it uses the world location instead of moving whats there to the origin.
Attached are the example files, I’m not sure what I’m missing as I’m not super familiar with Python
Fabtools GH Layouts still work in Rhino 7 for the most part, the Layout Manager aspect which can create from rectangles in the rhino model space does not. Due to sharing the same name as a Rhino command.
that works kind of when you boundary curve is close to origin otherwise,
I guess you have to think into two separate “world” inputs:
one boundary curve for what is the detail showing (G)
and the two corner points for the location on the layout sheet (PLT and PBR) where the bottom left corner is your origin
