Hi All, maybe not be related to Rhino, but has anyone try exporting Autodesk Robot model to a cad formats that carrier the steel profile assign onto it?
the dwg export only shows CAD lines only.
@jia.yeap you can use BHOM to import Robot Model in Rhino and then use Rhino.Inside.Autocad to get the data in Autocad from Rhino.
I have not tried this personally but this could be a possible solution.
