When I import Auto Cad DWG files to Rhino 7, some hatches don’t import together in Rhino 7.
Does anyone Can solve this problem??
Hi -
Can you please post a DWG file that shows this issue?
빌라사보아3층 최수호 202204326.dwg (245.9 KB) Yes, and My Rhino version is 8, not 7. Thank you…
Thanks!
I’ve put this on the list so that a developer can take a closer look.
→ RH-81539 File IO: Missing hatches from DWG
Hi -
The developers have taken a look at this file. The boundary curves for this missing hatch is self-intersecting in the bottom-right corner. Rhino will not create a hatch in this situation. You can either fix the curves in this area, or use the boundary option to create a region with the curves as they are.
I understand and fix it!!!, appreciate
