I am currently working on a uni assignment that requires me to decorate my design in a 2D fashion with hatches. I have gotten to the end and have found that the hatch on the left cannot and will not appear when I export as a DWG file. This is a screenshot of the hatches after copy and pasting them into a new file which is attached below. I have even tested doing it on this file and once again it does not work. I would appreciate any and all help in getting this resolved.
Could you post the settings that you are using when exporting?
And just to make sure, please also run the Rhino SystemInfo command and copy-paste its output here.
Additional note: does the DWG file that you export from Rhino import fine back into Rhino? You didn’t mention which application you are opening the DWG file with…
Hi Wim, pls find below the system info and a screenshot of the export thing below. And I did test it then, the dwg file can be imported back into rhino fine. Does that mean I have an issue in illustrator rather than rhino?
Accelerated graphics device with 4 adapter port(s)
Windows Main Display attached to adapter port #0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.6.1.0
It would appear so, yes.
I noticed that you are creating objects that are tens of meters long in a millimeter file. The smallest features in the file are ~3 mm, so that is fine for Rhino, but perhaps Illustrator has issues with this. Those two short curves of about 3 mm are both in the border of the hatch object that you are having issues with. I’d try simplifying that border curve and see if that gets things across to Illustrator.
