Array, orient and Graph-Mapper-scale Rhino-Geometry along curve
Hello dear community,
I started building a model with the great Rhino Plugin ArrayCrvPlus - it involves arraying, orienting and scaling a base geometry along a curve. The scaling is done according to.a two driver curves, independently for Y and Z axes of each element.
I’d like to build it in Grasshopper for the sake of quicker experimentation with different base geometries. I read many posts and tried to mix and match several scripts, but to no avail.
I don’t know how to use the Graph Mappers properly in order to scale the arrayed objects separately across their Y and Z axes, like in the Rhino example.
Any help is greatly appreciated!
Regards
Dimitar
Thank you Jack! Worked perfectly!
