Line facade.3dm (2.0 MB)
Hi. I’m trying to make my building’s facade as you can see I included the building in the uploaded Rhino file. My idea is to turn the pre-made shape/surface that is kinda tapered if placed against my building’s wall.
Goals is
- To divide the shape into lines
- Extrude/pipe the lines into wood “columns” as in 20cm x 5cm x 4m
Here I attached my supposed to be expected result
I’ve searched ways to do said “array” on surface, on two curve, on closed curve etc but is seems that my shape that is made by multiple planes and is on an angle that doesn’t fit with any tutorials I’ve found and tried so far.
May anyone tell me how to specifically make it on Grasshopper? Otherwise I may have to array pre-made columns manually per surface maybe? Thanks in advance!
