Hi, i´ve made a good tool to array a box along a curve with a gradient distance.
But now i want to array a individual rhino geo with the same tool along this curve.
Is there any option to replace the box by a geo from rhino?
Perfect, the V1 works fine. That’s exactly what I was looking for.
Is there (in the V1) any option to lock the original size of the brep? If i dont wont to resize the geo, just the array with consistant geo and gradient distance?
Thank you!
Hey, the file works perfect. But if a have more than one brep (5 in this exaple) i want to array on the line, only the last one in the list will be repeated, and on the last 5 points are the other ones.
Is there a way to solve this? an option would be to put all shapes in a separate brep, but this is super annoying for complex geometries!
The Group component did it for me.Multiple breps fed into a group then run through my script processes distributed everything perfectly. I had to UnGroup at the end in order to bake. It is easy to get lost in the complexity ofr what is possible in Grasshopper.
