Hi everyone! I’m trying to make an array of this small rectangle. I tried with the ARRAY CURVE in grasshopper but could’t make it work…does anyone know how to help me with this? Thank you!!
Hi!
Array curve on grasshopper works as in rhino: it picks your object where it is and repeat it by “flowing along a curve” … but that “flow” have a starting point.
On rhino the starting point (on the rail curve) is near the selection click-point; you can have “strange results” even in rhino, but rhino/gh are actually doing the right thing.
In grasshopper there is no “click-point” near one of the ends of the curve, so gh uses the START of the curve; you have to consider the direction of the curve and flip it if needed, see here:
I followed what I’ve seen in the pic…
If you attach your definition (+rhino file) it would be a lot easier.
