Hi there (and @jonm specifically) !
I was wondering if there’s an efficient way to process areas and volumes in GemetryGym directly, especially for walls for example, directly from the GG component outputs.
For Volume I currently use GGIFC ProductGetGeometry
associated with Volume
, but for Area i’m wondering how to do it clean and efficiently.
Hi Quentin,
Thanks for the question. I’ve considered in the past about enabling quantity extraction (software such as Solibri does compute this) but the question you raise is the same I can’t really answer.
What does the area of a wall mean? Is it one major face? Is it gross or net? If you know the strategy on how you would like to compute the area, I can help with how to achieve it.
If you can share files, that would help (privately is fine).
Thanks,
Jon
Hi Jon,
It was a general request. Usually i’d like to have two main areas computed:
- The gross area consisting of the area of my major faces (those that are automatically built from the
Path or perimeter
+Wall height
inputs forggIFC Wall Standard Case
component for example) - The net area where it is substracted the area of the openings (calculated the same way)
I understand there may be some issues with not fully in depth openings, some kinds of clippings and so on, but having a component that deals with the most basic configurations would be a nice adding.
Best
@jonm to be more exhaustive, please find a simplified example. I would basically like a component that simplifies all the red group. Here it’s pretty easy but from my experience it’s pretty quick confusing and a source of mistakes on more complex projects…
net and gross area.gh (30.0 KB)
