Hi when I type curve boolean and area to find the area closed by a planar closed curve, it prompts me to 1.74964546e+09, how can I change so that it would not have a constant in my area?
This is the E notation form of the scientific notation. It means the area is 1.74964546 x 109, which is quite large.
And if you want the output of the area
command in units that make more sense, you can run the dashed version of the command
-area
which will let you set the desired units for the output in the command line, eg. kilometers instead of centimeters.
HTH, Jakob
