Hi
I’m using a text field to calculate a curve’s area. In general this works but I’ve found a condition where it is reporting a negative area. The curve is closed and planar. Any ideas what would be causing this?
Negative area.3dm (32.1 KB)
Hi
I assume you are using DimArea
, which returns a negative value. Area
returns a positive value.
It may be connected with the curve being a polycurve of several arcs. If I rebuild it as a single, non-rational curve DimArea
