AR not in correct scale
I seem to encounter a lot of problems with getting models to the correct size when turning on AR.
Here is a link for some simple boxes that you can change the size of:
The size of boxes is in mm.
It seems that it loads all models at the same size, to begin with.
I have tested with a lot of different models now, and the scaling factor is not the same.
I also have problems loading large models (under 20 MB).
There is currently a default scaling factor computed for each model depending on its size. We are planning to release an update to the new platform by the end of the week which will include some scaling settings for AR in the Edit mode. I will let you know when this update is pushed, your testing is appreciated.
Thanks for clarifying
