API to EditPythonScript at a given location
Hi there,
I am writing a C# rhino common plugin which generates python code.
I would like to show the generated python code in Rhino’s EditPythonScript dialog and benefit from its syntax highlighting and code completion features.
Is there a way to programmatically instruct the EditPythonScript command to open a given file, e.g.
EditPythonScript “/the/python/file/which/i/generated.py”.
So far I only managed to open a file in EditPythonScript with user interaction via “File - Open”.
Many thanks for your reply.
Cheers.
Hi @Andrin,
The EditPythonScript command doesn’t have an option for doing this. But it seems like a reasonable request.
https://mcneel.myjetbrains.com/youtrack/issue/RH-69369
Note, the editor is being overhauled for Rhino 8. So if this issue is worked on, this is where you’d see it.
Thanks,
– Dale
RH-69369 is fixed in the latest WIP
