V5, V7
It occurs to me that whilst adding in various scripts, they being .rvb .py .rhp .txt and seeing the command line names that run them, or button if I decide to button a particular command, to have to try and remember these names , as well as other existing commands, as to what they are for, so as to pick the command to run for a certain task, means I need Spocks brain as the task isnt always the word as part of the command name.
example TweenCurves
before knowing the command I am trying words such as between and then array between, when wanting an even array of curves between two I pick. and nothing occurs in the hints list.
If I had a database, excel perhaps,
1st column plugin folder name, (for plugins and scripts such as .rhp or .rvb or .py)
2nd column name of file e.g. ObjectNotes.rhp
3rd name of existing command shipped with Rhino.
4th and subsequent columns key words.
For an existing shipped with Rhino command just dont fill in col1 and 2, col 3 would be TweenCurves, 4 would be between, 5 array, 6 evenly, 7 spaced, 8 curves
I could click top left on the excel sheet and search on ‘between’ and it would show the command and I can then type that into the command line.
However Excel doesnt do and function also or function
between and curves doesnt work.
Maybe Rhino provides this facility within the prog ?
Maybe someone has done this already in excel or access or a better prog ?
Cheers
Steve
