Any script to rename blocks and Layers in multiple .3dm files?
…sorry didn’t found any but also didn’t search that much.
If not I might try to make one… if so any suggestion where to start… I had some experience developing in rhino but it was a while ago.
Also, I’m a JS guy with limited Python experience.
Is there any advantage choosing Python over RhinoScript?
Namely relative to UI customization?
Maybe related Batch operations in Rhino files - Rhino / Rhino for Windows - McNeel Forum
Can this BatchSaveSmall.rvb be ported to python?
here: Batch operations in Rhino files - Rhino / Rhino for Windows - McNeel Forum
Is there a way to batch edit files without having to actually having a single Rhino Instance open them all sequentially? Any way to this “headless”?
And if not is there any way to speed it up?
I would prefer Python to RhinoScript cause I actually will need to use it elsewhere…
Hello- what, exactly, do you want to do?
Batch rename blocks in multiple .3dm files!
Would it be possible using Rhino - What is openNURBS?
I have a folder full hundreds of tiny files (cause I can’t reference a block within a 3dm file)
I want to rename layers to match the naming conventions.
Without opening this hundreds of files of course…
rhino3dm.js??
Does it even deal with blocks?
Home - Documentation
