So I trying to create a little script,BatchProcessFiles(), that allows me to run other scripts on multiple files. This is what I have and it seems to work pretty good from small scripts, like the the BlockNameTest(). It seems to inadvertently just stop though, if I use a larger script, for instance one that makes2D for all the viewports of a file and turns then into blocks. Any help to stream line it would be helpful.
import Rhino
def BlockNameTest():
BlockList = rs.BlockNames()
for Name in BlockList:
if rs.IsBlockEmbedded(Name) is True:
Path = rs.BlockPath(Name)
Index = Path.rfind("\\")
Index2 = Path.find('.')
FileName = Path[Index+1:Index2]
if Name != FileName:
Renamed = rs.RenameBlock(Name,FileName)
print (Renamed)
def BatchProcessFiles():
fileNames= rs.OpenFileNames("Pick Files To Process","RhinoFile(*.3dm)|*.3dm||")
for a in fileNames:
Rhino.RhinoDoc.OpenFile(a)
#Custom script Here
BlockNameTest()
rs.Command("-save _enter")
BatchProcessFiles()
