Any Idea How To Make Something Like This
I am a senior in an architecture program and I am working on designing a community center. I recently saw the image of a model on Instagram and would really like to figure out how I could make something similar on Rhino or Revit. Does anyone have any ideas on how to create the roof sweeping into walls?
basically:
then Sweep1:
If you have time could you try it with the line on the Y-axis like this:
When I did the Sweep it doesnt look as smooth as yours. Is it because of my rail that is not coming out as smooth or the settings? This is what mine turned out like:
A blend might work too.
Onetech,
Thank you very much for the suggestion to use a blend. It worked best so far.
Thank You,
Cory
