For text read from old files (Rhino 5) with undefined justification, the text is positioned wrong in Rhino6 SR11.
- Text created in Rhino5 with undefined justification gets a new origin (text plane) when opened in Rhino6 Sr11.
There is bug fix in SR5 for a similar issue:
https://mcneel.myjetbrains.com/youtrack/issue/RH-45939
pascal
(Pascal Golay)
2
Hello - how are you getting text in V5 with undefined justification?
Hi Pascal,
you get the text in V5 with undefined justification via python:
rs.AddText(“Hello World”, rs.WorldXYPlane(), 20, “ABCDEFont”, 0, None)
When saving the file and open in v5 / v6 the result is different:
Origin: 0,0,0 / 0,20,0 (absolute no go to change the text plane!!!)
With the command “what” you see in v6 a text height of 1.00 mm… Thats also not correct.
I attached the file.
R5_Text.3dm (16.3 KB)
Thanks,
Johannes
