I’m experiencing an issue in the layout view in Rhino 8 with VisualARQ 3. Occasionally, certain lines, texts, or dimension labels disappear randomly and do not display correctly. However, when I print the layout, everything appears as expected.
Could this be a graphics issue in Rhino? Has anyone encountered a similar problem or found a solution?
I’ve attached an example image where the title block, dimension texts, and some other lines are missing.
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 5-12-2024 (M-D-Y).
Primary OpenGL: NVIDIA RTX 3500 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 6-24-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.74
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-24-2024
Driver Version: 31.0.15.5274
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.1.0.1388
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
As a test, does the problem persist if you disable the third party plugins (In PluginManager, select “plugins that don’t ship with Rhino” , uncheck the plugins and restart Rhino)
