When I bulk export pdfs from layouts in Rhino 7 (7.3.21039.11202), randomly some annotation and dimension are missing or not displayed in the pdf. If I export every layout separately the dimensions are exported correctly.
Hello - is this random, or do certain items consistently fail?
The selection of items which fail seems to be random, to me. But they are consistently the same, when I export it several times.
Hi - We have several PDF export issues on the list. I think that RH-62446 covers most, if not all, of what you are experiencing.
Please post a simple file that shows the issue on your machine - perhaps there’s more going on…
Hi -
I realize there was no question mark in my previous post here…
Does RH-62446 cover what you are experiencing? If not, again, please post a simple file that shows the issue on your machine.
Hi, yes I would say this covers it. The only thing I would add, also some texts wich are on the same layer like the annotations are missing.
Hi -
Thanks for confirming that.
Have you tried using a different font for these annotations? I can’t reproduce that issue when I use the Arial font for all annotations.
you are right. If I switch everything to Arial, it seems to work at first sight.
