When the name of an Annotation style for an object existing in a project is changed, the Style field for the object in the properties window retains the former name. Confusion ensues. After the project is saved and reopened, the problem corrects.
This may be the case for all text objects, but it’s definitely the situation for text in blocks in my current project.
I guess you see that problem when you’re running BlockEdit after changing the style name. Is that correct?
II couldn’t figure out any other way to see it.
Have you ever seen any problem when the text is not in a block?
Thanks
