Hi, I want to program a wall with bricks, that have holes.
There I have a problem with a Loop in a Loop. For the Loops I used Anemone.
You can see, that the red group n the top should do the same like the red groups in the bottom, but if you look to the two results, you can see the diffrent.
This is the result with Loop in Loop:
This is how it should be:
Here is the code for testing:
2020-12-11_Ziegelscript_Fassade_Loop-Problem.gh (25.6 KB)
Does anyone have an idea how I can fix the problem?
Thanks
