Anemone – Closest Point from Curve to Curve
I need a proper Anemone pattern for “walk through a list of curves while passing a changing point forward”, using Repeat mode.
I have a list of 51 vertical curves, evenly spaced at 3 mm in one direction (already ordered).
I also have one point on the first curve.
My goal is to create a sequential closest-point propagation:
  • Take the point on curve 0
  • Find the closest point on curve 1
  • Use that new point to find the closest point on curve 2
  • Repeat this step-by-step until the last curve
I appreciate any support!
testing_T10.gh (91.5 KB)
Please right click and internalise the input curves
Done. Also noticed a duplicated Curve and fixed that.
Your curves were not sorted.
testing_T10 mrtn.gh (94.0 KB)
Thank you. Also i had to set the end loop on record mode. Otherwise it always gave me one point as output.
Heres everything cleaned up, if anyone else got the same problem:
testing_T10.g
h (93.9 KB)
Your image link is within the Grasshopper file link
