Anemone - basic folding example
Hi there!
I’m a newbie trying this anemone-folding example. I’ve followed every step of the script but somehow the last wire connector won’t come out as a dashed line. The example file is set with 6 slides and it shows the dashed wire connector as seen in this screenshot. I’m also supposed to get a bunch of lists as a result.
I tried figuring it out with panels to see what’s going on and my data is not reading entirely the number of slides I’m setting. Let’s say I want 6 slides (just as in the example) and it only reads the first and the last one (screenshot 2).
Does somebody know what is it that I’m doing wrong? I swear I’ve followed all of the steps.
I’d appreciate any advice, please.
Thanks,
Keyla
anemone_folding example.gh (23.0 KB)
fold lines.gh (19.9 KB)
I created this cluster based on that tutorial.
Honeycam 2023-08-11 12-04-45
You missed one crucial step.
Look at the Fast Loop End component from the tutorial file:
anemone_01
Now look at the Fast Loop End component from your code:
anemone_02
Note that it is missing the message saying Record at the bottom of the component.
You need to right-click on the Fast Loop End component and select Record data
After this, your file works as expected:
-Kevin
Thanks so much, Kevin!!
thanks!! :grinning:
