"An update is ready to be installed"
Anyone know how i can disable this notification which pops up every time i close rhino?
I have updated to the latest version so im not sure why i am getting it.
Can you share with us, which Rhino version currently you have installed?
You can disable it under Options
Thanks!
Hello- if you turn this off, you will not get actual updates - I’d like to sort out why you keep getting the message on closing - - I would reboot, start one instance of Rhino, turn on the check for updates, and click ‘Check now’ - what does that get you? If prompted to download, go ahead - close Rhino, run the downloaded installer and see if everything behaves OK now.
