An error occured in the display pipeline
Hi I’m getting this error:
An error occured in the display pipeline @ 00:28:23(869ms)
Message: Index was outside the bounds of the array.
Type: IndexOutOfRangeException
Does anyone know how it can be resolved? The geometry is either not being processed correctly, and or it’s not displaying within Rhino. The numbers after the @ symbol update to the current time as I pan around.
I’ve create a complex array of shapes and points within breps. The file does a lot of “in brep” analysis and then performs calculations on the objects within the brep. I’m mostly using standard plugins and Urbano. I also have a note out to the developer. I cannot post the original file due to NDA, but can answer follow-up questions.
Here is my systems information:
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Ti (NVidia) Memory: 12GB, Driver date: 3-16-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.41
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 9-2-2022 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-22-2022
Driver Version: 31.0.15.2802
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
Grasshopper debug file:
Document: …
Path: …
DocId: …
Modified: True
Context: Loaded
RaiseEvents: True
Enabled: True
Nested: False
Owned: False
Current Span: 1813.1041ms
Current State: PostProcess
Preview Mode: Shaded
Preview Filter: Selected
Preview Mesh: LowQuality
Schedule: -1ms
Subsidiary Tree
Object Count: 2064
Undo|Redo Server
Undo Count: 251
Redo Count: 0
Undo Names: Preview, Drag, Drag, Flatten, Drag, New wire, Drag, Flatten, Drag, New wire, Add Point, Drag, Drag, New wire, Flatten, Delete, Drag, Delete, New wire, Drag, Paste, Resize Panel, Drag, Preview, Preview, Preview, Drag, Drag, New wire, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Slider Value Change, Preview, Drag, Drag, Drag, Drag, Preview, Drag, Drag, Drag, Preview, Drag, Drag, Preview, Drag, New wire, New wire, Drag, Paste, Drag, New wire, New wire, Drag, Paste, Drag, Drag, Drag, Paste, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, New wire, New wire, New wire, Drag, Delete, Drag, Delete, Drag, Drag, Delete, Drag, Delete, Delete, Drag, Drag, Drag, Drag, Paste, Group, Group, Group, Drag, New wire, Drag, Drag, Drag, New wire, New wire, Drag, Delete, Drag, Drag, Drag, Drag, Paste, Drag, Drag, Drag, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Drag, Drag, Drag, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Drag, Drag, Paste, Drag, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Name change, Drag, New wire, Drag, Paste, Drag, Drag, Drag, Remove from group, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Paste, Drag, Delete, Drag, Drag, New wire, Drag, Paste, Drag, Drag, New wire, New wire, Drag, Drag, Paste, Drag, Drag, Drag, Set Point, Change data, Gumball drag, Slider Value Change, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Drag, Delete, Drag, Delete, Delete, Drag, Drag, Add to group, Drag, Drag, Drag, Add to group, Drag, Drag, Drag, Drag, Remove Parameter, New wire, Remove Parameter, Select: 4: Block Level, Drag, Drag, New wire, Drag, New wire, New wire, New wire, New wire, New wire, Drag, Drag, Add Data Dam, New wire, Drag, Add Data Dam
Event Server
Enabled: True
Update: False
encountered same error today. Can anyone help ?
encountered same error for a long time.
i start to find this in the rhino command line, it keeps popping up
Type: DocumentCollectedException
An error occurred in the display pipeline @ 17:38:11(158ms)
Message: Could not find DimensionStyle with ID 3d5e702f-e400-4c5a-809c-01f0137664bd
Most of the cases are normal, but when I open certain gh file, rotate the rhino window, and enter and exit the cluster within gh, the command line will always show that the display pipeline fails.
All conponent in this GH file are Rhino8’s own batteries.
Especially in shading mode, it is basically impossible to rotate or even crash. Wireframe mode is acceptable for speed.
the following capture is the rhino command line.
+1 Seems related to street hits…
