An error occured in the display pipeline - KaroroCAD in Rhino 8 Windows
Hi Guys,
I’ve tried to get a solution to my issue in other threads but those have seemed to have been lost over time.
My plugin, KaroroCAD, written in Grasshopper and complied using the Rhino Script Complier runs without major issues in:
Rhino 7 for Windows
Rhino 7 for MacOS
Rhino 8 for MacOS
However on Rhino 8 for Windows it loads with this error warning:
Command: -DK_Karoro_Kite
Solution completed in ~17.5 seconds
KaroroKITE Rhino Plugin 24.3.27
An error occured in the display pipeline @ 10:58:40(22ms)
Message: Object reference not set to an instance of an object.
Type: NullReferenceException
Command: _Enter
The same error happens around once an hour in use and 50% of the time will crash KaroroCAD/user loses unsaved work.
Does ANYONE have ideas on:
1/ What might be causing this error?
2/ How to trace the problem?
I’d REALLY like to have my plugin actually suitable for my customers to use in R8.
Cheers
DK
Rhino 8 SR6 2024-4-2 (Rhino 8, 8.6.24093.11001, Git hash:master @ de3127ef7b7fd6e4c2fef07a9a1bc10c8e1942a3)
License type: Commercial, build 2024-04-02
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [39% battery remaining]
Primary display and OpenGL: NVIDIA Quadro M1000M (NVidia) Memory: 2GB, Driver date: 6-22-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 513.29
Primary OpenGL: NVIDIA Quadro M1000M (NVidia) Memory: 2GB, Driver date: 6-22-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 513.29
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-22-2022
Driver Version: 30.0.15.1329
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Users\David Kay\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\KaroroCAD\24.3.27\KaroroCAD.rhp “KaroroCAD” 24.3.8851.24574
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.6.24093.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24093.11001
Screen shot of the error message I forgot to upload earlier.
Cheers
DK
You say that your plugin was written in Grasshopper and then compiled with the Script Compiler? Is it possible to send us your file so we can inspect and take a look. You can upload your file privately at Rhino - Upload to Support. Please include a link to this thread so we can track it properly.
Hi Andy,
Nathan is ahead of you and already got me to send a copy thru.
He’s told me he will look at it in the morning his time.
Cheers
DK
OK - @nathanletwory has been helping me out on this for the last week or so - thanks mate!
A lot of code clean up has been done, and some important errors sorted but no real progress on this issue until tonight.
I tried a trick someone else mentioned - copy the GH code to a new GH canvas and resave.
When I did this Shapediver suddenly popped up in my dependencies tracker. Shapediver was used in this code base YEARS ago but I’ve long deleted any components.
Doing a search of the canvas for Shapediver brought up this:
A blank piece of canvas showing up as a Shapediver component.
I was able to select and then delete this ‘component’ and have Shapediver come off my dependency list.
Compiled the code and installed into R8 and AND:
No Null Reference Exception on load up - weird fix but stoked to be getting somewhere.
Cheers
DK
Ok I’ve been working on this for a couple of weeks now and have the following notes.
‘an error occured in the display pipeline’ is a general error message from GH Player to the Rhino terminal.
This wasn’t present in Rhino 7.
It could be useful to change the wording and/or add more details of the components (GUID?) that has produced the error.
It would be useful to have control over this message as well? Maybe pipe to Rhino terminal for testing, but log it only for production, so not to scare the users?
Due to the way I turn off/on streams of data in my code to control compute time there were a number of ‘null reference errors’ on branches that are turned off during normal usage. The liberal application of Clean Tree components helped A LOT here.
I underlying crash issue seems to be some timing issues on page submit between WebView (R7) and WebView2 (R8) where it’s possible to double submit a page quick enough on R8 to crash the local webserver I’m using.
It fix this I’ve done two things.
1/ Changed my UI initialize/reload code to kill off the old server on restart of the UI, which allows recovery if the server crashes
2/ Added some JS code to the UI side that locks the page after submit to prevent resubmits.
All up the system is now working the best it has ever been on R8. If testing works out well over the next week or so I might be ready to recommend R8 for production use.
Cheers
DK
