OK, so KaroroCAD is broken in the latest service release.
Version 8 SR15
(8.15.24352.13001, 2024-12-17)
Commercial
My UI system is loading up fine and is responsive, so it appears my code is running fine in the background. Problem is ZERO geometry is displayed in the Rhino viewports - not on any display style.
Source code (R7 Grasshopper) loads/runs/displays in this version, just the compiled version is not working.
R8 does show this set of errors on opening the source:
Also this error code in the Rhino command line on opening the source:
K-cad loaded
Command: _Grasshopper
An error occured during GHA assembly loading:
Path: C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\WiresRenderer\1.4.5\WiresRenderer.gha
Exception System.IO.FileLoadException:
Message: Assembly with same name is already loaded
HELP PLEASE!
Cheers
DK
