Hi, i made this tower with square supports at the bottom and surface load at the top, but the Diplay (green) isn’t that optimized ? I should get a 4 columns, or whatever the optimization algorithm decides, from top to bottom as a structure ? @609999412
Hi Bilan
It is hard to tell without seeing the source file, but it appears like you’re using Ameba here? If so, you should be able to get support by contacting ameba@xieym.com
Cheers,
Jack
