Amd Radeon 580 RX very slow. Config problem or compatibility?
you could use the command _Testmaxspeed
but for a fair comparison you should make sure all settings are teh same, same viewport resolution (use a floating viewport), maybe start from a namedView, same geometry and mesh settings etc
you could also use holomark 2 for comparing the two systems:
