Hello! I’m trying to do a ‘mushroom shape’ in grasshopper with ribs and then I have to put a geometric pattern into the spaces between them in order to create a kind of sculpture (like the drawing). I show in the images to be clearer. I’ve created the ‘mushroom’ geometry with loft (step1) and then the pattern to put into (step2). In order to create the main ribs with the geometric pattern inside I’ve used the algorithm showed (divide domain2 - surface box - boxmorph) and it works, but as you can see (step3) it’s obviously not anymore a circle but it’s polygonal shape. Is there an alternative way to do it better or a plug in order to have the geometry curved?
Thanks!!
Try to use Sporph or Surface Morph instead…
