Tim_M
February 3, 2022, 6:15pm
1
As above I have lost all my tabs in grasshopper when using Rhino Inside. When I search I get the Red crossed out box.
I have recently installed RiR 1.4 and some additional plugins however my colleagues are using the same version of RiR, Revit with the same GH plugins with no issues.
I updated the Config file as per the troubleshooting guide with no effect. Rhino.Inside®.Revit
Command history does not show anything loading
Any ideas would be appreciated.
RhinoSystemInfo.txt (2.9 KB)
Japhy
(Japhy)
February 3, 2022, 7:03pm
2
Are they using 7.8 as well, lets get you updated to the latest version of Rhino.
Rhino 7 SR8 2021-7-15 (Rhino 7, 7.8.21196.05001)
Tim_M
February 3, 2022, 7:13pm
3
Sorry Japhy, I uploaded the wrong system info txt file that I had downloaded from another post on the same issue.
I am running 7.14. My colleagues are on 7.10. See attached the correct system info file.
Rhino system info.txt (3.4 KB)
Japhy
(Japhy)
February 3, 2022, 7:22pm
4
Rhino opens up normally on its own? This is only happening in the RiR environment right?
Can we do a team viewer? Rhino - Rhino Support
just private message me the code if that’s an option.
Tim_M
February 3, 2022, 7:27pm
5
Yes, everything works well natively in Rhino. Only happens in RiR. Thanks I will reach out
Tim_M
February 4, 2022, 4:52pm
6
This problem was resolved after an update of the Revit version and clean install of Rhino and RiR. Still not clear what the culprit was.
Japhy
(Japhy)
February 4, 2022, 5:17pm
7
Thanks for the update Tim, glad you got going.
