I’m having this constant problem, it’s not everytime.
When I finish using “Trim”, the shaded viewport goes to wireframe mode.
Do you have a repeatable example file someone here can look at and test?
Maybe also run SystemInfo in Rhino and copy/paste the results here…
Does mean that you have a bad object sometimes when it does that? —-Mark
If it’s only the object that goes “transparent” I would say that is most likely the case. However they said “the shaded viewport goes to wireframe mode.” Which implies to me that everything is now in wireframe. That implies something else wrong, perhaps graphics card/driver issues. No way to tell without more info.
