Hello there,
is it possible, that the AddLoftSrf Rhinoscript command is broken in RH7 SP0?
I use it as always :
Loft = Rhino.AddLoftSrf(arrForLoft,0,1,45,False), but the curves are not rebuilt.
Rhino tries to loft it like ist was “Does not simplify”.
In RH6 SP31 everything works like intended.
the style parameter is not accepted.
The 1 should cause a rebuild of the curves, while the 45 stands for the 45 control points. As seen in the picture, the curves are not rebuilt.
