Hi everyone, I’m wondering why Rhino 7’s Loft command in Grasshopper doesn’t create simple surfaces (even with the Rebuild option), just breps and with horrible performance - more than 6 s to just loft a few lines into a few curves… In Rhino 6 this is not a problem and it takes about 100 ms…
Rhino 7:
in your definition Loft options has a “rebuild” value, which means that whatever joined poly-curve you input will be rebuilt as one single curve with those control points
Wow, that’s weird… My version was (7.1.20343.9491, 12/08/2020) and even with rebuild set to 20 it still generates just breps. When I use a Rebuild component before the Loft (which has it’s own rebuild, but it doesn’t seem to work) everything is fine…
