I can’t figure out why my script is crashing rhino. I can successfully complete the layout but not the detail.
The instant before rhino crashes a white rectangle appears on top of all four rhino viewports. Its definitely something that I am doing wrong. Not a rhino problem.
@dale
I still can’t figure out where I am going wrong.
I copied your code while inputting the gh variables in place of the things that I wanted to change to no avail. I also change the document settings from mills to inches.
Here’s the result.
Good Morning @dale
Here is the Gh File I cannot get to work. Layout bounding box.gh (8.9 KB)
Thank you for your patients with me. It is much appreciated.
@dale
Something interesting. If you watch the last second of the capture the It shows the default 4 view (Unintentionally) and there is a little grey viewport tab right behind the (Top) Viewport Tab.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Scan&Solve Pro for Rhino 6 & 7\SnSPro_Rhino_6+7.rhp “Scan&Solve Pro for Rhino” 1.0.0.0
I know I am tacking onto an older post, still this year though.
I am running into this same exact issue. I can create the layouts in gh no problem, as soon as I try to use the AddDetail function Rhino crashes.
