I’ve done this multiple times in a couple of plugins, but creating a new plugin, I’m stumped how to add a win form.
I’ve added System.Windows.Forms to the dependencies assemblies, but when I right-click the project name and select “Add”, “new item” doesn’t list windows form as an option.
Thx. Is there a way to recover from dumb mode, having not checked that box when creating the plugin, or do I have to create a new project and check the box?
As you can see on the left, the default is to create a .Net Core only plugin, by checking the Winform it will add the WindowsForms framework logic (seen on the right).
You should download and install the latest Rhino Templates extension for Visual Studio. I also recommend installing Visual Studio Community 2022 if you are still running 2019.
Thanks Dale, I’ve seen this posted many times, and actually tried to start from there, but I don’t think it’s that easy, at least for me… I have succesfully tried the “commands” plugins, but never the “forms”.
I’m trying to make a command, which makes you select a curve (this part I have it covered) … Upon selection, I want a menu (similar to attributes) to trigger, on which I can populate with different options for a given geometry (like sliders, drop down menus, toggles, checkbox, etc…
So, I believe Rhino UI is the kind of solutions I’m looking for.
Appreciate the help if you have any, and if not thanks anyways!
P.D: I’m not really looking for anyone to solve my problems, I’m just trynna find better resources for me to learn. I know the Rhino-developer samples can be very helpful but can sometime be overwhelming when you have no idea what you are looking at.
