The novice rookie asks every teacher VB.NET to write the plug-in, after adding the form, how to refer this form to the rhino
If you have a Rhino plug-in project, written in Visual Basic, and you’ve added a form, you can display it from a command like this:
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
Dim result As Result = result.Cancel
Dim form As New SampleForm()
Dim dialogResult = form.ShowDialog(RhinoApp.MainWindow())
If (dialogResult = Windows.Forms.DialogResult.OK) Then
result = result.Success
End If
Return result
End Function
Does this help?
– Dale
