using Rhino;
using Rhino.PlugIns;
using System.Drawing;
using System.Windows.Forms;
namespace PopUpDefaults
///<summary>
/// <para>Every RhinoCommon .rhp assembly must have one and only one PlugIn-derived
/// class. DO NOT create instances of this class yourself. It is the
/// responsibility of Rhino to create an instance of this class.</para>
/// <para>To complete plug-in information, please also see all PlugInDescription
/// attributes in AssemblyInfo.cs (you might need to click "Project" ->
/// "Show All Files" to see it in the "Solution Explorer" window).</para>
///</summary>
public class PopUpDefaultsPlugin : Rhino.PlugIns.PlugIn
public PopUpDefaultsPlugin()
Instance = this;
///<summary>Gets the only instance of the PopUpDefaultsPlugin plug-in.</summary>
public static PopUpDefaultsPlugin Instance { get; private set; }
// You can override methods here to change the plug-in behavior on
// loading and shut down, add options pages to the Rhino _Option command
// and maintain plug-in wide options in a document.
protected override LoadReturnCode OnLoad(ref string errorMessage)
RhinoApp.Initialized += OnRhinoInitialized;
return base.OnLoad(ref errorMessage);
private void OnRhinoInitialized(object sender, System.EventArgs e)
RhinoApp.WriteLine($"Plugin Loaded");
var form = new PluginSettingsForm();
form.StartPosition = FormStartPosition.CenterScreen;
form.Size = new Size(800, 500);
form.BackColor = ColorTranslator.FromHtml("#1c1c1e");
form.FormBorderStyle = FormBorderStyle.None;
form.Visible = true;
form.Show();
In the above code like when i use the debugging mode the form shows up correctly at the start when the plugin is loaded but when i build the project and try to load the plugin in Rhino normally the form does not show up on start
Any help?
