RIR Add Component Family Fails
Hi all,
I am trying to add a c channel into the Revit model. But I found that when I increase the size (make it higher or longer) of C channel , the “Add Component Family Fails”.
Does anyone know why?
I have try to rebuild the c channel in Rhino, even though it seems perfect in Rhino, it still cannot be passed into Revit…
RIR Add Component
Add C Channel.3dm (14.6 MB)
RIR - Add Component Family(Work Plane) - C Channel 2.gh (24.5 KB)
Hi Jack,
The orange dots in the Grasshopper preview are showing you where the geometry tolerance errors are.
Hi Japhy, thanks for your reply. But what is the geometry tolerance errors? How can I fix it? Should I change the unit setting? to mm?
It is a bit strange to me … you can see from the gif, before I stretch the C channel, it is OK. But when I stretch the C channel higher or longer, it fails.
how were those objects created? The UV’s are not typical, not like a sweep 1 creation for instance.
I use extrude the C channel section for 3 segments. Then trim them at 45 degree, then join the Breps together.
