RiR - AddBeam.ByCurve
thanks for the awesome work.
I’m having problems with AddBeam.ByCurve component for Revit.
As soon as I change the geometry (with slider) i get an error:
However, as soon as i disconnect the input geometry, and reconnect, the error is gone.
Thanks!
E.
Hey @shabicedin
Welcome to the community. Would you mind translating the first two warnings?
Thanks :slight_smile:
Hi @eirannejad,
here the error translation:
  1. Object reference not set to an instance of an object
  2. Position for cutting plains leads to inclined pillar without geometry
I also found a bit older but apparently not cleared thread, with the same problem:
Thanks!
I had same problem, today I have downloaded the source project and recompiled
linking the revit 2020 libraries, then got the new rhino wip and it seems that the problem
is gone
gd
thanks for your answer. I was hoping for a fix.
I think it will be difficult to get the corporate IT to compile source code…
+every time a new Version is out.
EDS
