Hi all, I wonder if there is a way to add model text into Revit using RIR?
Hi Jack,
Placing a Family with user text is a good workflow currently available in RiR.
I added your desire for a native Model Text component.
Great, thanks Japhy!!
Hi Jack, It looks like you are running into Revit Tolerances with your 10mm text (the actual geometries of the characters being much smaller)
https://www.rhino3d.com/inside/revit/1.0/guides/rir-grasshopper#tolerances
Is it possible to adjust Revit’s minimum tolerance to allow the display of small objects?
The Revit tolerances aren’t affected by Rhino, these are hard coded into Revit and not accessible via Revit API.
So I cannot even adjust the tolerances in Revit?
