I wanted to add a button on popup menu. However, I couldn’t get the icon image automatically. I thought if I copy&paste a command, the associated icon image would be copied over as well. On popup menu, it showed blank. I had to shit+right click on an existing button from the full tool bar in order to export the bitmap (couldn’t find where original icons are saved); then import back on the popup menu editor. This is quite involved. I initially thought I could just drag a button from toolbar to pupup editor menu. Is there something I am missing? Is there an easier way to add icon bitmap on the popup menu?
Hello - is the goal ito copy a button from one toolbar to another?
basically yes, I’m looking for an easy way to add a button to pupup menu–hopefully drag&drop. The way I have been doing is:
- create a new button for the popup
- copy a command and paste in the popup menu edit window
- export an existing icon bitmap from an existing button from the full toolbar menu.
- import the icon bitmap in the popup menu edit window.
All these could be replaced with simply dragging an existing button to popup menu edit window?
Hello - to copy a button from one toolbar to another , hold Ctrl and left-click and drag the button to its destination.
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#user_interface/using_toolbars.htm?
Thank you very much. Exactly what I wanted.
One thing to note is in case other people have the same question, it cannot be dragged into the popup menu. The popup menu first needs to be docked in; then a button can be Ctrl+dragged. After that, the popup menu can be undocked to only appear with the mid click.
