Windows 10.0.22000 SR0.0 or greater (Physical RAM: 31Gb)
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 8-5-2021 (M-D-Y).
> Integrated accelerated graphics device with 3 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.78
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-5-2022
Driver Version: 30.0.15.1278
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\aesth\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “ConnectorRhino7” 2.5.1.14260
C:\Users\aesth\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\aesth\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Karamba3D\2.2.0.14\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
Sorry for directly tag @dale , I have searched some posts and seems you might familiar with this issue I am facing. If not, I am so sorry for bothering and my rudeness.
And also thanks for your time.
It might because I used xdata to set one extend data directly but it didn’t know it’s a pair data. So I guess the part I should put more efforts in should be how to setup the pair xdata in Autocad directly.
I’ve used it for a couple things but just playing around. If you’re wondering about the code itself AfraLISP.net is the best AutoLISP site out there (for tutorials).
I was using xData in conjunction with reactors (Reactors - Part 1 | AfraLISP) to create “Revit” style tags for objects. Worked wonderfully but only had limited testing (for example, if I had a large drawing with many objects it might have been laggy (lots of iterating through each object was required).
