About the Octane category
[Replace this first paragraph with a short description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters. Until you edit this text or create topics, this category won’t appear on the categories page.]
Use the following paragraphs for a longer description, as well as to establish any category guidelines or rules.
Some things to consider in any discussion replies below:
  • What is this category for? Why should people select this category for their topic?
  • How is this different than the other categories we already have?
  • Do we need this category?
  • Should we merge this with another category, or split it into more categories?
Are you going to fill out the description, or should we just assume the topic is about Octane? :smiley:
Here @andy can you use this Category Desc?
The Octane Category for Rhino3D is for tips and support for using the Octane Plugin for Rhino, or specific techniques that improve Rhino’s use when exporting or importing .obj meshes and Octane materials to/from the Standalone Octane Renderer.
Paul Kinnane (paulphysicalc) is the Octane for Rhino Plugin Developer.
Before you request help, READ THIS from Paul and search the OTOY Rhino forums too.
This forum it is not for help in using the Octane Standalone Renderer, except as it applies to importing back into Rhino.
For help with the Standalone version of Octane, OTOY has very active forums at: Octane Commercial Support Forums
As well as good sub-forums on using the Rhino Plugin. “face_off” is Paul on the OTOY forums.
